they won't split like rubber and also harder for them to 'blow off'what is the benefit of going to hard pipes? Do the stock rubber pipes flex that much? Whenever I consider a hard pipe set, the thought of the metal transmitting extra heat to the intake air system seems to negate any benefit metal pipes might give. Am I totally off?
I'm in the process of upgrading my turbos and running more boost, so I want to get all the supporting mods out of the way. I had a friend that ran more boost on one of his cars and he kept on blowing his rubber tubes. Plus on an older BNR32 like mine, who know's how long it will be before they start to show their age?what is the benefit of going to hard pipes? Do the stock rubber pipes flex that much? Whenever I consider a hard pipe set, the thought of the metal transmitting extra heat to the intake air system seems to negate any benefit metal pipes might give. Am I totally off?
what turbos/boost level are you going for? And what was your friend running?I'm in the process of upgrading my turbos and running more boost, so I want to get all the supporting mods out of the way. I had a friend that ran more boost on one of his cars and he kept on blowing his rubber tubes.
