1 - 18 of 18 Posts
Is there away to connect harness to the isofix slots in rear attachment of some kind,just don't want a bar in the back and will only use harness on trackdays.
to be 100% clear....i screwed in new bolts with eyes into the current mounting points for the rear seat belts and then clipped the harness to that....hope that helps..
I did the same...undid rear seat belt bolts as they go into chassis, fitted harness bracket with the standard bracket and put bolt back in.
Easy job. No need for a bar.
Discussion Starter · #8 ·
Cool so rear seat out unscrew seatbelt bolts
Fix harness bracket in place of seat belt using original bolts
Seat back in???
No fit harness brackets as well as seatbelt ones....:)
the only issue it think we had was to put a slightly longer bolt in the position under the front seat where you lap belt goes to on the gearbox trunk side...
Anyone got any links to kits for this setup? Fancy fitting some harnesses myself.
Take not that this dangerous in an accident du to the rising angle of the belt to the shoulder strap.
Because it's a fair angle off horizontal there's a large vertical component to the tension. If a crash throws you forward, there's a massive amount of force pulling you down by the shoulders and crushing your spine.
If you can't do it properly with a bar, personally I wouldn't do it at all, unless you can use the upper seat belt mounting brackets, they would be perfect.
If you can't do it properly with a bar, personally I wouldn't do it at all, unless you can use the upper seat belt mounting brackets, they would be perfect.[/QUOTE]
+1 :thumbsup:
you pays your money and you takes you chance...the choice is yours...
I know that I would rather have a set of 3inch wide harnesses on me in the event of a crash on track than the standard belt that is the norm at every trackday.
If those 3" harnesses are set up to compress you in a crash then I'd definitely prefer to take my chances with the factory belt - as said above, proper height harness bar or no harness for me!
Even well fitted harnesses kill people in crashes. That's why Hans devices are mandatory across almost all Motorsport.
I had a long and interesting discussion some years back with a neuro surgeon who does a fair bit of decent level amateur Motorsport. He was of the opinion that fitting harnesses without a Hans could potentially be more dangerous than wearing a standard seatbelt. Inertial seat belts fitted as standard allow the energy of deceleration in a crash to be dissipated through your torso rather than just your neck and base of skull when wearing just a harness.
It was the reason why I never fitted them to my car.
Depends on the nature of the crash but yeah, constraining your shoulders just leaves your head to whip back and forth in a longitudinal impact and possibly snap some vertebrae if you do it well enough!
That said, I had a 4 point and bucket in my old mx5 daily driver. I rolled that a couple of months back and walked away completely unharmed. I'd have done much worse if I wasn't wearing the harness, but if someone had shunted me at traffic lights it could have been a different story!
1 - 18 of 18 Posts
