Has anyone fitted this bar on their gtr?
i wonder if it will fit?
i know there's DW and other brands, but i dont need the ball joint and rods etc....just wanna disable the hicas.
thx
Owner of the MSNSPS
I have something broadly similar.
It's a bar/tube which locks the OEM arms in place. Mine seems to work fine and unless your arms are shot I cannot see any advantage in replacing them.
The logo on the above suggests in might be for a Z32 300ZX. AFAIK the rear set-up is the same for the Z32 as the R32.
that will be a hicas deletion kit, but will only really work if the car is stock ride height.
if you start lowering the car, the "pick up points" will need altering. i.e that too will need lowering... otherwise, oversteer city !!! unless its a drift car, then this is fine.
