1 - 17 of 17 Posts
My R35 s Alternators get some wrong and get bad charging at idle RPM and low RPM.
it make all the light flashing when i turn the right signal light on.
After drived it for a while. the problem is gone.
Should i change the Alternators?
Thx
Sounds like the battery more than the alternator
I changed the battery already. It work normal in the few day I changed. But it s again now.
So it's OK when you've charged the battery but not when you haven't and recovers when the engine is run for a bit = battery
Smells like an advert to me. Why have a company name in the thread title when you would typically replace with OEM?
Time to do a bit of digging.
I am from Taiwan that why my English like a small child. Actually i can find this brand making after market alternator only
Ah, my apologies. Guess your English is way better than my Tiawaneese.
Haven't seen the brand. I would stick with OEM or a regognised brand.
Must be pattern parts available now. Check online.
Still looks like an advert though :)
Taiwanese or Mandarin, both impossible
Discussion Starter · #10 ·
Anyway! My car is getting worst. I dont think it is the fault of the alternator. All the the light is flashing***65292; when i put the transmission to N. Any suggestion***65311;
It's the battery
How about loose drive belt, loose alternator connector or bad earth? All worth checking before spending on a new alternator.
Togo already mentioned he changed the battery which solved the issue for a while, then it's back again.
Missed that on the phone, multimeter on the alternator then and see what that's putting out
check the voltage across the battery when the engine is running. If less than say 13.2 then you know you have a charging problem.
I suspect TAZZ is right. There's very little to go wrong in an alternator. Most likely a poor earth strap or poor drive to the pulley.
1 - 17 of 17 Posts
