When my car is cold the fluid in the pot in the boot seems to rise quite a bit above the maximum mark but when the engine is run it sinks between the min and max mark, is this correct?
If so when do you check it to fill it, cold or hot engine?
I recently bled the system through by undoing the bleed nipple on the transfer box and letting it pump the old fluid through while i topped it up in the pot.
Thanks.
