Hoping to get some feedback on whether the Hawk Performance Ceramic pads are any good for road use and maybe a track day or two. I know they are now track rated pads but how do they compare to the Brembo OE pads?
Hawk Perf. Ceramic Brake Pads Front HB650Z.730
Also my discs are showing small cracks around the drill holes, maybe a few mm top and bottom; I have been advised to drill them out to stop the cracking progressing; is this a good idea?
Hi,
The hole drilling of your OEM Brembo's is a long job and you are delaying the inevitable really. But in answer to your question yes it can be done.
Also if you get a set of pads now they will bed to the shape of your discs.
The Hawk PC's we can have in a few days or we stock the HPS compound stock here in the UK which is very similar. They are a street pad however they would be an improvement over the OEM Brembo material. Would compare this to a DS2500 material performance is similar with less dust.
Any more info please ask. Or drop me a PM if you would like a set
