I started doing the head today and what a tricky job it is to remove the turbos! Still I have started so will finish.
Couple of questions,
How do you get to the rear water pipe going into the turbo?
Also there are two oil lines going into each turbo I guess both these need to be removed before the turbos with the manifolds can be pushed away from the head... or do I need to remove the turbos from the manifold as well? Downpipe is already off.
Also when taking off the heat shields, 2 of 3 bolts snapped inside the manifold.. is that normal? I guess the shield is needed when I finally put everything back?
