I cannot seem to get hot air blowing in my car, Ive checked pipes going in and out of matrix (both hot) Ive flushed out with garden hose Ive bled and bled and bled, engine temp good (81),water pump fine,Ive cleaned the little sensor for the climate control. HELP, I'm freezing.
First off, did the matrix flush ok in both directions ? Did you keep flushing untill the water was clear ?
And Do you have air blowing from the vents (even if its cold air) ?
I assume yes to those, then its one of the controll flaps either broken or the servo that alters it is inop
Do these cars have a pollen filter ?
Mark.
Yes it blows, and i suppose ill try flushing somemore, like my old radiator it might never flush clean enough, had to change rad even after leaving it in acid for two days, thankyou,
