1 - 20 of 40 Posts
The 4wd light has been coming on from time to time for the
last couple of week's, Fluid in the resovoir in the boot is on the
max, fuses are ok as it is just an intermitant fault.
The attesa unit under the parcel shelf is flashing 18 equal length flashes.
Anyone Know what this code means? Cheer's C.
Anybody got a full list of the code for future reference and newbies ?
Thanks in advance,
Paul.
Banned
Could be an intermittent fuse fault. I experienced one of these before it went completely.
Ahhh reviving a dead thread....anyways...saw these on another post...I take no credit for writing them up.....only for the copy/paste. hehe
1 – Right front wheel speed sensor or circuit
2 – Left front wheel speed sensor or circuit
3 – Right rear wheel speed sensor or circuit
4 – Left rear wheel speed sensor or circuit
5 – ABS right front wheel actuator solenoid or circuit
6 – ABS front front wheel actuator solenoid or circuit
7 – ABS rear wheel actuator solenoid or circuit
8 – ABS actuator motor, motor relay or circuit
9 – ABS actuator relay or circuit
10 – ETS control unit power supply or circuit
11 – Fore-and-aft G sensor 1 or circuit
12 – Fore-and-aft G sensor 2 or circuit
13 – Fore-and-aft G sensor 1, fore-and-aft G sensor 2
14 – G sensor power supply 1 or circuit
15 – G sensor power supply 2 or circuit
16 – Lateral G sensor or circuit
17 – Air bleed connector or circuit
18 – ETS pressure switch or circuit
19 – ETS motor, motor relay or circuit
20 – ETS solenoid or circuit
21 – Throttle sensor or circuit
22 – ETS oil level switch or circuit
Hi,
i am having the same type of problem with my R33 GTR V-Spec it is saying ATTESSA error code 77
does any one have a listing for R33 GTR V-Spec ATTESSA E-TS Pro fault codes?
thanks any help would be appriciated.
im getting 75,quite annoying as nobody seems to know the fault codes.
Hi,
mine has been resolved it turned out to be the ABS/4WD computer itself it had water damage, the rear window wiper seal was stuffed and water dripped into the computer cost me $1200 to get a new one
my boot has been letting in quite a fair bit of water lately.had to get one of the light resealed.i hope i dont need to replace the computer.what does code 75 mean on the 33 vspec?
im still getting this,it used to happen just now and then.every time i drive the car the light comes on after about 2-3 mins.this is really annoying.do i need a new throttle position sensor.my mechanic tested it with a multimeter and it seemed ok.really confused.any help appreciated!code 75 every time
I had an R33 GT-R that was getting a code 75. I checked everything. Tried everything, replaced the computers , the TPS , checked all the wiring.
The problem - the ground wire on the alternator was loose. Tightened it up , and it went away , and never came back. I would have a good look at the grounds.
i disconnected the battery today for 1 hour.it hasnt come on since.but was quite wet today,so didnt really give it the beans.usually comes on very quickly when im giving it some welly.if all wiring is ok,what is next step.repace tps?
Did you read what I posted above ? I tried all that stuff , and it ended up being nothing but a loose ground wire. I would go over all that stuff first. Same code, same car , I would check it before you go and spend too much money.
ok i ahve this code as well "18" so where is this pressure switch? easy to replace?
1 - 20 of 40 Posts
