1 - 11 of 11 Posts
its only held on with double sided sticky tape....heat the part up and then gently pull it away from the body.
3m tape on both
top GTR logo section first
drive a plastic wedge carefully into the end nearest the door and create a gap then CAREFULLY trim through the adhesive with a craft knife
the lower vented section will then simply pull out with a little back and forth twisting
edited to add putting some masking tape on first is best practise and be gentle or you will make a dint
3m tape on both
Are you sure you've done this sort of thing before,,Mate
1 - 11 of 11 Posts
