My car is booked into the tuners on the 7th April to have new turbos fitted and a re-map.
Thing is, I just did a compression test.
Here are the results(taken from cold):
Cyl 1 - 167 psi (11.5 bar)
Cyl 2 - 80 psi (5.5 bar); i dropped a little oil in the chamber and managed 8 bar (116 psi)
Cyl 3 - 148 psi (10.2 bar)
Cyl 4 - 185 psi (12.75 bar )
Cyl 5 - 130 psi (9 bar)
Cyl 6 - 162 psi (11.1 bar )
Treat cylinder 1 as the front cylinder (I may have them in the wrong order).
So apart from them being all over the shop, cylinder 2 is quite low, as well as cylinder 5.
A bit of history surrounding the engine. The engine was running fine until I detected a whiff of oil. After removing the turbo piping, it was clear there was plenty of oil in the inlet side of the turbos as well as inside the mushroom filters, down in the re-circ tubing etc. etc.
Thinking this was the seals on the turbo - I then replaced the r33 standards (incidentally with no play) for r34 standards.
During my test drive, over-boosting the ceramics, I shattered the exhaust turbines on the r34 turbos. I am almost certain I kept my foot down at the time they went.
I need to really get an idea of which way to go now as the car is booked in for this turbo swap.
I am starting to wonder if the oil present from around the turbos was in fact due to Cylinder number 2 and not leaking seals on the turbos.
J.
J.
