1 - 15 of 15 Posts
Fitted up the gearbox today having done a dummy mount before. The speedo drive cable fits straight in but there should be a clip to stop it from popping out.
yes theres a fork and a bolt! plus you have pushed it in to far! the fork sits in a groove in the drive!
Need to connect up the switches. I have a feeling the one towards the bell housing is the reverse lamp and the on towards the transfer box is the neutral switch. Can someone please confirm.
Skyline Section Manager
The fork appears to be part of the speedo sensor according to FAST.
Discussion Starter · #8 ·
I have looked everywhere for the fork cannot seem to find it which is bloody frustrating. Are the forks different for the 34 and 32?
Discussion Starter · #11 ·
I found the tab was in the box of all the bits I got plated.
Any ideas about the neutral and reverse switch?
Off the top of my head I can't remember! But I'm prety sure reverse is the rear switch!
Easy way to check is with a voltmeter!
As above, best way to find out is to test.
With multimeter on ohms and test across each plug. With the gearbox in reverse you should have a circuit across one plug, that will be the reverse switch/light circuit.
1 - 15 of 15 Posts
