does anybody know anyone around reading that is a mobile fitter as i have a problem a clicking sound from the top of the engine, tappets i think and a squeaking noise also from the top a mate put a new timing belt on for me as it pos it could be a tooth out and could the squeaking be the belt is to tight ????????????????? thank you for looking.john
John, turn the engine over by hand and check the cambelt timing is correct.
until this is done, don't run the engine again.
Where the tensioners replaced with the cambelt? Used tensioners have been known to make noise when a new belt is fitted.
