Hi peeps
As I am still stuck and can’t find a Toyo Proxes T1R 275 x 30 x 19 ANYWHERE. Toyo UK are out of stock..
Does anyone know if or have fitted 295 x 30 x 19 (to a 10” Rim) from a different manufacturer will work with the 275 x 30 x 19 on the front axle?
Also, if they will fit under the rear arches (think they will as I measured over 300mm from the suspension upright to the outside of the bodywork last night)
i.e. the rolling radius and the way the centre diff works ? Seem to remember having a set on new tyres on the rear and part worn ones on the front and it causing the 4 wheel system to think something was wrong and was active all the time.
Steve
Steve
