I didn't think GTR's were different from other motors, but someone correct me if I'm wrong here....
Ok, set the crank to TDC. Either by aligning the dot on the crank drive gear (for the timing belt) with the mark on the oil pump, by using the crank pulley marks or by the old school way of setting #1 piston (the front one for noobs) to TDC by putting a stick or dial-gauge down the spark plug hole and turn the crank one way till you get to the top, mark where the crank is, turn the other way till you get to the top, mark where the crank is then set it in between the two marks (if using a dial-gauge the marks should be pretty much in the same place). Remember that both intake and exhaust cams need to be in about the right place otherwise "problems" may occur!
now that the crank is at TDC, line up the marks on your cam wheels and install your cam belt.
When changing belts, I always set the motor to TDC on #1 first - a lot less stuffing around!
hope this a) makes sense and b) helps!
*edit: Ahh, Chris not only beat me to it, but included a picture! clever trousers that man!
