I hope you don't mind me invading this forum, being a Ford RS Owner!! I have found that 'our lot' can't help much with this kind of stuff!
I borrowed a Blitz SBC for the Ten of the Best day recently and got on really well with it. We then decided to buy a Boost Controller, but went for the Apexi AVC-R after doing a bit of homework. The problem is this.....
We cant set the damn thing up!!
In the Boost/Duty menu, I have the Boost set at 1.00kg/cm and the Duty at 50%. Set this way I can get the car to make the desired boost (about 1.5 bar), but it doesnt hold onto it very well. The only way I can raise the boost from this menu is to adjust the Duty, adjusting the boost seems to have little or no effect.
I have put X's in the Gear Judge and F/B Speed menu's and have also found that I seem to be able to alter the boost in different gears by changing the percentage in the Start Duty menu. (I am not absolutely certain of this though)
The reason I am a bit vague is because I cannot currently drive the car on the road, so my time for experimentation is limited. I do have use of a Rolling Road. I am getting really frustrated with it!!
Thank you in advance for any help you may be able to give me.
