press start twice without your foot on the brake.Can someone please tell me if it is possible to have your Cd/Music box/MFD on without the car running ?
Thanks for that will give it a go.Another tip is that if you want to switch the engine off but keep the music playing then press the start button twice in quick succession. The music will not cut off if you get it right.
Most like stiction in the spring/damper assembly I would reason: eg spring plates graunching as they are partially unloaded in droop then reloaded?Thanks for that will give it a go.
I have another question that you guys may be able to help with.
When my son is in the car ,he sais he can hear a sound like a bunch of keys being rattled comming from under the car.I cannot hear the noise from the drivers side of the car.The noise only happens when we go over a bump !!
Any suggestions ?????![]()
