Just pulled up into my drive, turned the lights and the car off and the side lights [front and rear] + the dash lights won't go off even though the switch is off and the ignition is off...
If anyone has experienced this or has any idea how to rectify it, please let me know ASAP as my battery is dieing!!!
Obviously I can disconnect the battery, but any other suggestion would be appreciated
If I disconnect the battery the only thing i need to worry about is the front wheels being dead straight because of the HICAS reset - is this the case?
Thanks in advance for any suggestions people - cheers..
Oh, I forgot to say the car is a late BNR32..
And the only other thing worth mentioning is I had to drive through a rarther large puddle on the way home, could there be an earth problem due to the water?!?!
