1 - 10 of 10 Posts
Got the cover and fuel level sender off, I can see the pump but is covered. How do I remove it with out braking anything as I am not sure if its a clip or need to remove some bolts.
Need to verify the kind of pump I have fitted as the car was raced in Japan before being returned to normal.
You should have this in the bottom of the tank which the pump sits inside its easier to remove this as a complete unit by sliding it in the direction the pump is facing which I think is to the passenger side
Automotive exterior Bumper Auto part Vehicle
Auto part Automotive exterior Vehicle
It just slides to the left but I'd does have lugs as you can see on the side so as not to come loose you just slide it off but it may take a push and get some marigolds as it's at the bottom of the tank
The pump cradle points down and towards the left (passenger) side. To remove it, get your fingers round the back of the cradle (i.e. the driver's side) release the clip which you should be able to feel, and slide it up and towards the driver's side.
1 - 10 of 10 Posts
