well, just ten days after blowing my engine, I've managed to source and order a staggering list of parts - engine internals (I went with HKS nickel-plate pistons), conrod bolts, all sorts of bits and pieces, new turbos, water injection system, gauges galore, Datalogit, wideband lambda...everything.
Except:
transmission crossmember bushings. Turns out my car only had two out of four installed, and the two remaining rubber ones are shot. HKS Kansai among others make aluminum upgrade bushings, but I can't for the life of me track any down.
Anyone know where I can score a set?
Why don't your keep your R32 rebuild in one thread as it will be easier for people to follow your progress rather than every time you get a problem start a new thread.
You had already started a thread on "transmission crossmember bushings "
http://www.gtr.co.uk/forum/upload/66797-transmission-crossmember-bushings.html
And one on your car rebuild
http://www.gtr.co.uk/forum/upload/66827-2barboys-rebuild-thread.html
Not to mention the other countless threads you have started reguarding your R32 GTR
Just finding it hard to follow:lamer:
