I have a le mans skyline Gtr V - spec. running at about 700bhp has a 2.8 stroker kit on steel headgasket greddy sump extension, uprated injectors fuel rail and fuel pump. twin T67 Tubos fcon pro unit etc etc.
my problem is. its massively overheating. running into 120 + degrees when the car is under load even at 3000 revs. cools down on idle. i only drive 1 mile not even in boost and the temperature hits the red.
oil pressure runs at 4.5 on when warm at 2000 revs idle runs at 2.5-3
oil temperature runs at 90.
fuel pressure 3.5
also oil catch tank has a lot of condensed water ( engine blows off a lot of steam). oil is ok though.
one problem i have noticed is a loose wire on the fcon unit which we have just found last night and hopefully rectified it. (moved a green wire and a blue one and the engine cuts out.) however. now the engine is idling at 1300 revs.
any ideas..
fuel pressure 3.5
any ideas..
