hi i think i have a suspension problem, but could also be hicas. while driving down road a small bump will make the car twich and squirm alot. and never feal's sure footed through corners anymore. had car on four wheel tracking and they said it was .4mm out (this was done with the engine off would it make a difference if hicas was working[engine on])? also the rear drivers side tyre had to be replaced after only a few monthes because it had worn a 15mm strip off the inside edge down to the metal. can anyone tell me the geometry settings for an r33 gtr? thanks in advance for any help
simon
