I don't know whether anyone else has experienced this but my R33 GTS revs seem to bounce when idling. If you stand outside the car you can here it reving between 600 and 1000 revs, then it will go click and idle OK for a bit then back to bouncing. It seems worse when I switch the aircon off, I assume because the air con boosts the revs anyway. I hae got the standard air filter and it obviously gets worse on hot days.
Any help much appreciated.
