1 - 16 of 16 Posts
Does anyone know the test sequence & fault codes for the R33 GT-S HICAS system?
My dash light HICAS indicator lights up occasionally so I presume that suggests that I should check the fault codes.
I know the codes for the 240Z series but not the Skyline.
Does anyone have the information on the R33 codes?
Fault codes
Send an email to the skyline librarian Phil (location Manchester - so you get the right one). He should have the codes.
R33 Hicas codes
Attn Dave Wilkins
Thanks for info Dave
I have only just joined the Register today so don.t know my way around yet
Can you give me a bit more of an address for Phil in Manchester ??
No problem.
<Top line of screen> Click on 'members'
Click on 'P'
Click on 'Phil'
Click on 'Send Phil an Email'
Try that!
OK Stupid question time here!!!
How do you get the ECU fault codes anyway?????????
Does this help?
Fault Codes HICAS 1989-1993
1 HICAS solenoid right hand
2 HICAS solenoid left hand
3 Cut off valve
4 Power steering solinoid
5 Vehicle speed sensor
6 Steering angle sensor
7 Neutral position sensor
8 (Auto) Parking brake sensor, (Manual) Clutch sensor
9 (Auto) Inhibitor switch, (Manual) Neutral sensor
Fault Codes HICAS 1994-1999
11 HICAS control unit
12 HICAS motor power supply not present
13 HICAS motor output not present
21 Vehicle speed sensor not present
22 Steering angle sensor not present
23 Steering angle sensor neutral or not present
24 Rear main sensor input not present
25 Rear sub sensor input not present
31 Parking brake sensor input not present
32 (Auto) Inhibititor switch input not present(Manual) Neutral switch input not present
32 Engine speed signal not present
Procedure
1. Switch ingition off, put car into neutral.
2. Start engine
3. Very quickly (within a couple of seconds), turn the steering wheel left and right about 20 degrees from centre five times, and then pump the brakes five times, then press the brake pedal once more - this will enter diagnostic mode.
4. Drive forwards or backwards about 5 metres at a speed less than 5mph, this will enter full diagnostic mode.
5. The HICAS light in the instrument cluster will be flashing quickly (for normal) or will flash a code indicating any problems.
The long flashes are for the first digit
Short flashes are for the second digit.
This will give you the number you need.
Diagnostics will return to normal after five minutes, or any speed over 5mph, or ingnition is turned off.
Simple really;)
John
1 - 16 of 16 Posts
