My HICAS warning lite on my R33 GTR keeps coming on at random times, sometimes right after I start the engine, sometimes when i am driving, any ideas what the issue could be? the steering feels fine and there are no other problems, I'd like get some expert advice here is anyone has seen this on their car before I spend money at a garage.
If you have a speedo convertor fitted this is usually the culprit, nothing to really worry about :D You'll know if you have one as the 180KMH clocks will now be running at 180MPH.
Dave.
mine has started doing this also.
Done it for the first time while being mapped on 4 wheel dino.
Done it again the other day while sat there running. (didnt drive any where but came on after 2 mins sat there)
I dont have a speedo convertor.
I have ordered a lock out bar as i dont trust the hicas and now it has come up with a fault im getting rid of it.
HICAS LIGHT
I had same problem the solution for me was replacing the terminal block on
the positive terminal of the battery the one that was fitted was a slack fit
and corroded since i have replaced it the light only comes on during start up
I got the replacement from a 4 year old nissan in my local scrap yard (no cost)
took 5 mins to change out.once done give it a good coating of petroleum jelly
keeps the damp out.
Gordon rose
