1 - 19 of 19 Posts
I think it's time to change the Hicas oil. However I couldn't find with certainty what type of oil to use.
I have a japanese book that probably explains what type of oil to use unfortunately I don't read japanese :nervous:
Could someone translate this to help :
I''m not sure it's ATF because when it is you can see ATF written even if it's japanese (this is the case for the R34 gearbox for example). But ATF isn't written in the japanese description posted. That's the reason I believe it may not be ATF. Thus a translation would be very usefull.
Hi Wardiz
Have you tried a phone app to translate the text ? A mate used one on a trip to Germany recently and it worked really well. You literally aim at the text like your going to take a photo and it translated.
Can find out the app if your interested ?
Darren
Skyline Section Manager
The HICAS is just stock autobox oil. Nothing special there.
If you own a 33/34 your hicas is electronic not hydraulic :thumbsup:
But yes ATF in 32's. (In the pas reservoir in the bay).
Bob
Discussion Starter #10 (Edited)
It's a R34. I know the HICAS is electronic still there is an oil tank in the boot as in the picture.
Or is it the Attesa oil tank ? I'm getting confused :confused:
Am I the only one who is confused he wrote hicas and there is a pic of the Attesa reservoir tank?
The text is saying: Nissan power steering fluid special.
You must be right mate that must be the ATTESA oil tank !
What should I use then ? I guess there must be an alternative to the "Nissan power steering fluid special" ?
Hicas is electronic
What you see there is the fluid for the hydraulic side of your diff
So you should have a factory fitted lsd ?
So yes it's Attesa....
LSD on non v-spec. Hydrolocally operated LSD on v-spec.
ATTESA fluid is used to operate the 4WD and diff on v-spec.
Discussion Starter #14
You are right, thanks.
Back to square one : what type of oil should go in Attesa actuator ?
I did some research and I found this : http://www.gtr.co.uk/forum/471778-post1.html
Basically the oil is obviously some ATF oil BUT it's not advised to use dexron II or dexron III because the viscosity a 40°C is too high (35.5 according to spec).
I spent some time comparing the spec of various ATF oils of various brand at 40°C. And the range goes from 38.5 to 29.6 (second is 30.5). So more than 20% of difference.
Question to oilman : do you think it's safe to use an ATF oil with the lowest viscosity @40°C in the attesa tank ? Is 30.5 mm2/s is low enough ? (it's the Motul ATF VI).
Sorry to bring this topic UP.
But I find so different answers... nissan matic D, dexron III, dexron II...
Like wardiz mention there is also differences between brands
So should I go for the lowest viscosity ATF oil I can find ? (like the valvoline )
"There is a control side, and the actual transfer case. The fluids in the control side, and the transfer are separate. Nissan says Nissan special power steering fluid in the control side, and Nissan Fluid Type D in the transfer case. (We normally use Redline High Temp ATF in both systems.)"
ATF1100 in the Hicas and power steering in mine R32 GTS-4. so far so good.
1 - 19 of 19 Posts
