HICAS
Hi,
On an R33 you can pull out the fuse,I guess the R32 is the same.On top of this you can weld the Hicas components to stop any movement at all.OR give Stillen a phone call they produce a Hicas eliminator Kit for the 300zx possibly the same for the R32?or I`m sure you can modify it.
www.stillen.com
800/9290332 orders only
714-540-9154 prices & tech info
(both phone numbers are USA numbers but I guess you know this anyhow)
Good Luck,
Henry:smokin:
you need to make a hybrid power steering pump from a standard GTR one and another nissan one such as a primera , Croydon Wholesale have done this to their car and have reduced the weight significantly . I can get contact details of the guy who did it if you want to talk to him , he is also the guy that drives it most of the time , he has a best of 10.5 1/4 mile in it.
Brenhan.
There ara a few Hicas cancellers on the market. I also have a mag with the instructions on how to do the operation and it seems very easy.
There are also Attesa E-TS controllers
