i recently replaced a throttle body on my r32 gtr and while they were off i cleaned the other 2 before fitting.now my car wont tickover below about 1250rpm any reason for this that could be a common prob.a m8 said that if you clean them then you take the teflon coating off them which will give you high tickover is this true and if so how do i cure this ,car runns fine apart from this any advice much apreciated cheers
