A guy was after making a wiring harness a while back so i took mine off my car and belled out all the wiring on it. I have triple checked it and am sure its right.
This harness is needed to go between the 4wd ECU socket and its associated wiring loom plug. Not sure how much use it will be as sourcing the male and female ECU connectors was a problem for the guy i sent this diagrame too.
Anyways here it is hope it helps someone
Right on mate. Im sorry if this sounds a bit dumb but to my teck this will help him to wire it into the car correctly? I have a HKS unit and it has all the factory plugs and harnesses but i have no clue where to hook it all into. Thanks again
hi chaz,
do you have the set up for the boost control side ofthings mate? there are 3 flexi pipes in the engine bay and i have no idea what they connect to.
cheers
Nick
