Hi guys, i have just installed the EVC 6 (the new one with color screen) and the unit showing no error when i set the target boost to 90kpa but i can only get right around 60kpa (stock boost value). I have tried reset everything and started from zero but still can't achieve the target boost. I have also tried to adjusting the offsets as described in the manual, verified the lines are correct and checked the waste gate type is correct.
I have been searching in other forum as well and said make sure to set the maximum standard boost setting to a value just below what the car makes on the waste gate spring after the EVC is installed. Tried this as well but didn't work. Confusing..
Any thoughts?
JK
Any thoughts?
JK
