Banned
i got a r33 gts with the HKS evc already installed, the only problem is there is only the power wire coming into the cockpit, from the black vacuum box, now there is two units which go inside the car one is the adjuster and the other is display. does anyone have any installation info on these, ive already searched. thanks in advance for any help.
HKS USA EVC IV Instructions - Install
The above should help you. It's the installation manual from the HKS website.
The wiring is pretty simple anyway. The red is ignition feed, and black wire is earth.
The rest is all fool proof connectors
I guess you'll have to speak to one of the HKS dealers, and see if this is available as a seperate part.
