The V-Pro is very good, getting quite long in the tooth but a comprehensive ECU.
I've got one (HKS F-Con V Pro Gold) for sale for £400 with MAP Sensor, Air Temp Sensor and Harnesses.
You do away with your Air Flow Meters so do not have to swap when you max out voltage on stock RB25DET unit (over ~350bhp)
32x32 bit tuning resolution, Apexi Power FC is only 20x20.
It also has automatic air/fuel ratio compensator so you should never run lean on a F-Con.
Tuning wise- these tuners will be able to map the F-Con for you (I think),
GT-ARt
Abbey Motorsport
Sumo Power
TDi South
TDi North
+ more (anywhere that sells HKS Parts and has a Rolling Road)
