as long as your ECU knows it's running 700cc injectors (as well as the latency time), you can run whatever turbo setup you want. Injectors are variable, they're not 100% all the time. So I'd say it's smart to go with injectors you'll grow into, rather than the perfect fit now, and then have to replace those later on.
