Hello everyone
please forgive me for asking about some new turbos. I know there are a gazillion threads about it :shy:
I wasn't into turbo cars for quite some time so i'm not up to date.
I recently bought a car from here (Spec below as i can't post links now) but unfortunately the turbos are gone. both compressor wheels are damaged and one has a massive play.
What i want:
- twin setup on stock position as i won't get through our "TÜV" with a single or a top mount twin setup.
- ~600HP with potential to increase if i want to. The car ran [email protected]
- response
should i rebuild the turbos or get something else?
If new ones, what would you suggest?
cheers,
Mark
Specs taken from the sales ad here
RK Tuning 2708cc Built Engine
• N1 Engine Block (New from Nissan Japan)
• RK Tuning 2.8l (+2mm) Billet Fully Balanced Counter Crankshaft
• CP Custom 86mm Forged Pistons
• Eagle Con-Rods
• Fully Rebuilt, Ported Head with Oil Gallery Mod
• Apexi Power FC with Hand Commander
• Trust Sump Pan Extension
• HKS Twin GT-RS Turbos
• HKS Steel Head Gasket
• HKS Turbo Extension Pipes
• HKS Stage 1 Cams
• HKS Adjustable Cam Gears
• HKS Uprated Actuators
• HKS Fuel Pump
• HKS Fuel Reg
• HKS Fuel Rail
• HKS 700cc Injectors
• HKS Intercooler
• HKS Thermostat
• HKS Oil Cooler
• HKS Intercooler & Hard Pipe Kit
• HKS Powerflow Filters
• Trust Down Pipes
• Fujitsubo Legalis R Cat-Back Exhaust
• HKS EVC
• ATI Super Damper
• OS Giken Triple Plate Clutch
• Clutch Conversion Kit (From Pull to Push)
• Nismo Slave Cylinder
• Trust Triple GT Radiator
• Iridium Spark Plugs
• Splitfire Coilpacks
• Trust Rear Diff Case Upgrade
• UK Spec Gearbox Cooler
• UK Spec Diff Cooler
What i want:
- response
cheers,
Mark
• Eagle Con-Rods
• HKS Stage 1 Cams
• HKS Fuel Pump
• HKS Fuel Reg
• HKS Fuel Rail
• HKS Intercooler
• HKS Thermostat
• HKS Oil Cooler
• Trust Down Pipes
• HKS EVC
• ATI Super Damper
