Does anyone know which toggle switches need to be on in order for the navigator to read ecu data ?
Supra RZ · Registered Joined Feb 6, 2003 · 597 Posts Discussion Starter · #1 · Nov 19, 2009 Only show this user Does anyone know which toggle switches need to be on in order for the navigator to read ecu data ?
Nocturnal · Registered Joined Nov 5, 2004 · 2,548 Posts #2 · Nov 19, 2009 Only show this user Check if your ECU is F-Con V-Pro 3.1 or above, other wise it wouldn't work. Navigator Pro will only work with V-Pro 3.2 and above as far as I know.
