1 - 13 of 13 Posts
For sale: HKS R Type intercooler. Brand new with brackets. Still boxed and never fitted.
600x300.5x103
£980
Will post anywhere in mainland uk. Contact for quote.
Discussion Starter #7 (Edited)
Is it tube and fin or bar and plate?
Introducing the new HKS R-Type Intercooler Kit. The new R-type core was developed specially in order to improve response. Because a front mount layout usually has the detriment of slow response, the pipe layout is designed as straight and short as possible. It enables as quick boost response as stock intercooler. When a vehicle is stopped, stock intercooler core keeps heat inside from the engine compartment and then, when the car starts, sometimes knocking occurs and engine is damaged. Front mount intercooler decreases intake air temperature (20 deg. C less than stock intercooler) and it enables safe and reliable tuning.
Features:
Bar and Plate Design
Front Mounted
_______________________________________________
R TYPE is designed for circuit use; ideal to use with a stock replacement type turbine to wastegate type large size turbine. This intercooler derives better turbine performance regardless the engine rpm during driving on a straight track and acceleration after cornering.
The weight is approximately 25% lighter than a conventional product. (In-house comparison).
(1) Inner Fin (triangular straight type)
Triangular straight type for less pressure loss of air flow.
(2) Outer Fin (triangular louver type)
Like S TYPE, Triangular louver type for outer fin.
1 - 13 of 13 Posts
