1 - 11 of 11 Posts
My car is fitted with one of these. It's the first turbo car I've owned.
Can anyone explain to me how they work?
The hiss seems to come from the intake side.
Yeah, sorry. Actually that doesn't quite answer my query. I think I understand the principles of the BOV but it was more to do with the HKS one in particular. The sound of the pressure release seems to come from the air filter area, rather than the inlet manifold side where the actual valve is, or have I got it completely wrong?
Banned
That means its not working, or youve got a recirc one.
If its a normal ptchhhhh sound from the inlet its a recirc valve.
Its its flutter/chatter sound then the valve isnt working and its just doing what it would naturally do without a valve, and your hearing the pressurised air escaping back out the turbos when you let off.
Discussion Starter #8
I'm not even sure now that is what is on my car? I think I need someone who knows about these things to look over my car sometime.
Discussion Starter #10
Right, I've been under the bonnet today to try and suss things out. It's definately an HKS sequential BOV. It says so on the valve.
I'm not sure if what I did made any difference but I pushed the valve in with my fingers (engine off) and it seemed to 'pop' in, as if it was stuck. I started the engine and revved it a few times with my hand over the end of the BOV and it is definately working, so I took the car up the road. Noise still the same!
Is it possible that the noise I hear from the driving position is an intake 'suck' rather than the BOV dump??
Having said that, the car seems to pull smoother now. Maybe the BOV was stuck shut? I don't know. Happy days! :)
Dunno mate - without seeing/hearing it it's gonna be hard to say. But if it's working ok and the car's driving sweet then just grin and bear it pal :D
1 - 11 of 11 Posts
