Removed from my HKS T51 Turbo as i changed my fittings / lines, this will suit any turbo that uses 4an fittings
This is the oil feed line with 4an fittings at the end of either side of the line
The braided line is also covered with a heat insulation tubing
Will try get a better pic up tomorrow but you can see it from the pic below
40 euros
still have this available if anyone needs it, will fit any turbo which uses a 4an fitting
new pics
