Hi all,
Serious Performance are very pleased to announce that we are now the European distributors For Hosecoil Washdown Systems :smokin:
We are carrying a small amount of stock at present but, the first two items are here and ready to go! Quality is excellent and given the usual 'plastic fantastic' that is virtually all the other hose guns etc on the market, these are very competitively priced as well.
If people want to have a look at the rest of the Hosecoil range it's here: www.oceanequipment.com. If theres anything in particular people want just let me know otherwise we will be building stock up gradually over the next month or two.
Given that Hosecoil use their own connection system to fit their hoses, we will initially be supplying a hose attachment to fit any Hozelock type connection.
The first two products are below with RRP prices. More products and prices to follow very soon! (Any product requests from the Hosecoil ranges just let me know).
Hosecoil Suds Blaster - £21.99
Adjustable 9 pattern spray dial
Inline soap resevoir
Contoured rubber grip formed over strong metal body
Stainlaess steel components
Soft fingertip trigger control
Variable flow adjuster
Soap shut off
Hosecoil Mud Blaster - £9.99
Autowash nozzle with variable flow adjuster and metal body finished with a durable epoxy coating. Heavy rubber rivet handle. Adjustable spray tip. Brass valve stem and stainless steel components. Select from a fine mist to jet stream with a twist. Positive twist shut off.
GTROC discount, will as normal apply to the Hosecoil range :smokin:
Cheers.
Alex.
