In my never-ending quest to turn my R32 GT-R from an expensive ornament into a correctly functioning vehicle, my attention has been drawn to the throttle position sensor. I've been advised that a faulty throttle position sensor could well be causing some of the idle fun I've been experiencing.
Soooo....
Can someone explain to me how I can best check to see if it's working ok? I've got a Power FC & Hand Commander if that makes any difference?
Cheers,
Jim
The PFC shows the TPS voltage Jim. I thought this may be the cause of my idling problem but after checking the PFC readings it has turned out not to be the case.
Go to the main menu (press prev until you see 3 option Monitor, Settings, Etc) on the PFC and go into the "Etc" option
Then go into the "sensor readings" option (2nd one down) and you will see all the sensor readings --- o2 sensors, TPS, AC and Idle off/on , neutral detector etc
Brian
Perfick :D Cheers Brian - am off to have a fiddle (oo-er) :D WITH THE CAR!!! (honestly....sheesh!).
