1 - 7 of 7 Posts
Its more a question of the fit being different due to the NVCS, It can be done but not with anything off the shelf mine was made for me
Pope
For R33 inlet we make our own adjustable pulley's, don't think there are any off the shelf pulleys for the intake of a R33 RB25det.
i.ve been working on modifying the tomei pulley have it on there now i'll post pic's of the bit's i made to fit it, all i needed to know was it could be done and you can't buy it off the shelf, thanks robopope and r.i.p.s nz:bowdown1: , as for shanef i take it you never fitted one before,
nope never fitted an adjustable one, but have pulled stds off countless amounts of times, i just assumed they woulda just made them to bolt straight in (only 4 or so bolts holding it on isnt there?)
there is 4 bolts holding the exhaust pulley on and 4 small bolts holding the plate over the 1 oil fed m12 x 1.25mm bolt holding the nvcs pulley on when you have it off there are 4 bolts holding the pulley together, had to get a shorter bolt with no oil feed hole in it and the thread all the way to the end, have it now but it was hard to find,
1 - 7 of 7 Posts
