1 - 6 of 6 Posts
I've undone and removed the 6 bolts but can't get the prop off the diff.
I'm removing the rear subframe and nearly ready to do so, but don't want to damage either the diff or prop.
Is it ok to drop the subframe? Will they come apart or not?
Thanks in advance.
should come apart if all bolts are loose . Have you tried a hammer to shock them loose . Could just be corrosion holding them together
I'll have a look, the prop appears to be sitting is a sort of cup coming out of the diff, another reason I didn't want to force anything.
1 - 6 of 6 Posts
