1 - 16 of 16 Posts
how heavy and what power is the new gtr? Thanks.
Edit, forgot to add..... is it still using the same altessa system?
Er... about 480 bhp standard, no?
:D
1740kg and 478-485bhp
A more modern ATTESSA ET-S 4wd system is now used with a 6 speed dual clutch gearbox, rear LSD and VDC-R.......:blahblah::blahblah:
Trav
Discussion Starter #6
lol, there are few different numbers there. Anyone want to confirm which post is correct? Thanks.
The below is taken from - Nissan GT-R Black Edition
ENGINE
- 3.8-litre twin-turbocharged V6
- Dual overhead camshafts with variable intake-valve timing
- Die-cast aluminium cylinder block with high-endurance/lowfriction plasma-sprayed bores
- Aluminium pistons
- Nissan Direct Ignition system with iridium-tipped spark plugs
- Electronic drive-by-wire throttle
- Pressurised lubrication system with thermostatically controlled cooling and magnesium oil sump pan
- Fully symmetrical dual intake and low-backpressureexhaust systems
- Secondary air intake system to rapidly heat catalyststo peak cleaning efficiency DRIVETRAIN
- ATTESA ET-S Four-Wheel Drive (4WD) with patented independent rear-mounted transaxle integrating transmission, differential and 4WD transfer case
- Torque distribution - Traction/yaw-based; up to 100% rear; up to 50% front
- Rigid, lightweight carbon-composite driveshaftbetween engine and transaxle
- Electronic Traction Control
- High-performance 1.5-way mechanically lockingrear differential
- Advanced Electronic Stability Program (ESP)
with three driver-selectable settings
TRANSMISSION
- All-new GR6 6-speed Dual Clutch Transmission with three driver-selectable modes
- Fully automatic shifting or sequential manual control via steering wheel-mounted paddle shifters
- Downshift Rev Matching (DRM)
- Predictive pre-shift control (in R-mode) preselects the next gear change based on throttle position, vehicle speed, braking input and other information BRAKES
- Brembo® 4-wheel disc brakes - 15" (380 mm) front and rear
- Two-piece floating-rotor front and rear discs with diamondpattern internal ventilation
- Super-rigid 6-piston front/4-piston rear monoblock callipers with racecar-inspired 3-point mounting
- 4-wheel Anti-lock Braking System (ABS)
- Electronic Brake force Distribution (EBD)
- Nissan Brake Assist
AERODYNAMICS
- Coefficient of drag - 0.27
- Negative lift (downforce) generated at speed- Full underbody covering
- Body-colour rear spoiler with integrated centre high-mounted stop light
- Knife-edge front wings, designed for optimised air management around the wheels and to help keep the side windows clearer at driving speed
- Optimised airflow through the undercarriage and wheel arches to help cool the engine, drivetrain and brakes STYLING/FUNCTIONALITY
- Automatic headlights
- Wide-beam headlights with High Intensity Discharge (HID) xenon low beams
- LED taillights and brake lights
- Dual heated body-colour power outside mirrors- Flush-mounted aluminium door handles
- Quad exhaust exit pipes with chrome-tip finishers
- UV-reducing solar glass
AUDIO/NAVIGATION/PERFORMANCE MONITOR
- Digital Bose® audio system with AM/FM/CD, 11 speakers (including dual subwoofers), Radio Data System (RDS),
and MP3/WMA CD playback capability
- Steering wheel-mounted audio controls
- Multi-function meter
- Monitor also provides displays and interface for programmable vehicle settings, vehicle information, audio and navigation systems CONVENIENCE
- Intelligent Key with engine start button
- Electronic analogue instrument cluster with multi-function trip computer and digital gear indicator
- Dual Zone Automatic Climate Control
- Power front windows with one-touch driver-side autoup/down
- Remote windows down
- Key-operated windows up/down
- Remote keyless entry with boot release
- Cruise control with steering wheel-mounted controls
- Tilt and telescoping steering column
- Variable-intermittent flat-blade windscreen wipers
- Dual illuminated visor vanity mirrors
- Front centre console with armrest, storage and dualcupholders
- Rear centre console with dual cupholders
- Map reading lamps
SUSPENSION AND STEERING
- Front suspension - Double-wishbone with aluminium members
- Rear suspension - multi-link with aluminium members
- Rigid aluminium front and rear suspension
subframes, assembled in high-precision jigs, with 4-point mounting to body
- Bilstein® DampTronic system with three
- Hollow front and rear stabiliser bars with tubular torsion-free design, to help maintain maximum tyre contact at all four wheels during extreme cornering
- Electronically controlled rack-and-pinion steering with vehicle-speed-sensitive power assist
- 2.6 steering-wheel turns lock-to-lock WHEELS AND TYRES
- Super-lightweight RAYS seven-spoke 20" diameter forgedaluminium wheels with ridged bead area
- Black finish
- Exclusively developed tyres, nitrogen-filled at factory
- Standard tyres - Dunlop SP Sport 600 DSST
- Tyre Pressure Monitoring System (TPMS)
BODY CONSTRUCTION
- All-new Premium Midship platform with hybrid unibody
- Aluminium bonnet, trunk lid and outer door skins
- Die-cast aluminium front shock towers and door structures
- All outer body panels stamped using multiple-strike coining process, for exceptional rigidity and precision
- Carbon-composite frontcrossmember/radiator support
- Advanced 6-stage paint process with full double clearcoat and chip-resistant paint in critical areas SEATING AND TRIM
- Leather front seats with perforated Pearlsuede inserts
- 8-way power front seats with entry/exit switch forrear passengers
- Driver and passenger sports seats
- Dual individual rear seats
- Leather-wrapped steering wheel and gear knob
- Drilled aluminium pedals
- Leather-trimmed dashboard, console and door trim
- Brushed metal interior trim
SAFETY
- Nissan Advanced Airbag System with dual-stage front driver and passenger airbags
- Driver and front-passenger side-impact airbags and roof-mounted curtain airbags
- Front seat belts with pretensioners and load limiters
- 3-point ALR/ELR passenger seat belt system (ELR for driver)
- Zone Body construction with front and rear crumple zones
- Bonnet buckling creases, pipe-style steel side-door guard beams, and energy-absorbing steering column
- ATESSA ET-S Four-Wheel Drive with Electronic Traction Control
- Electronic Stability Program (ESP)
- Nissan Vehicle Immobiliser System
- Thatcham Approved anti-theft system
TECHNICAL DATA
MODEL R35
Engine type VR38DETT
Configuration V6 incorporating DOHC
Cylinder bore x stroke (mm) 95.5 x 88.4
Displacement (cm3) 3799
Compression ratio 9 : 1
Max. power output (PS/rpm) 485/6400
Max. torque 588/3200-5200
Fuel supply
NISSAN EGI (ECCS) Electronic controlled fuel injection system
Recommended fuel Premium, plus unleaded
Fuel tank capacity (l) 71
TRANSMISSION
Transmission type GR6 Dual Clutch
Transmission
1st 4.056
2nd 2.301
3rd 1.595
4th 1.248
5th 1.001
6th 0.796
Gear ratio
Reverse 3.383
Final drive ratio 3.700
Driven wheels 4WD DIMENSIONS
Overall length (mm) 4655
Overall width (mm) 1895
Overall height (mm) 1370
Max. interior dimensions
(length x width x height) 1750 x 1475 x 1095
Wheelbase (mm) 2780
Track Front/Rear (mm) 1590/1600
Min. ground clearance (mm) 110
WEIGHT/CAPACITY
Kerb weight (kg) 1740
Seating capacity (persons) 4 (2+2)
Gross vehicle weight (kg) 1960
PERFORMANCE
Acceleration 0-60 mph (sec) 3.5
Maximum speed (mph) 193
Min. turning circle (kerb to kerb)
(m) 11.4
Urban (mpg) 15.4
Extra Urban (mpg) 31.0
Fuel consumption (mpg) Combined 22.8
CO2 (g/km) 298
Main Emission Control System Variable valve timing
OTHERS
Steering
Electronic controlled power-assist rack and pinion
Suspension Front/Rear
Independent double wishbone suspension /Independent multi-link suspension
Braking System Front/Rear
Ventilated brake disc /Ventilated brake disc
Tyre Size Front/Rear 255/40ZRF20 97 /
285/35ZRF20 100Y
Nobody knows. The R35 is actually fitted with an advanced Malteaser AWD system. Some people have complained that the handling is soft round the edges.
LMAO poor asked a question and got all this, fair enough he could have looked for nissan website but funny nevertheless
or simply looked on Google...
It's the most written-about car of recent years. The info ain't exactly hard to find! :chairshot
Having said that, they definitely are not producing just 485ps. Minimum 500hp on superunleaded and LOADS more torque than claimed too. Just put yours on a rolling road if you don't believe me.
Guess what, R33s didn't produce 276hp either! :D
Discussion Starter #11
ye look on google and you get different answers every where like i got on here!
Thanks for the replies that made sence people.
So it seems its weight is around 1750kg and power is somewhere between 470-510 ish!
1750kg is the declared weight of the car, though I suspect that with the Premium trims (heated seats) and Bose sound system (11 speakers etc), this may be higher for some models.
The reason for the differences in power is because of
a. different model years (original JDM release was 480ps. 2009 models was supposed to be 485ps)
b. some magazines claiming the published hp numbers were underdeclared because some of the dynos were reporting pretty high dyno figures.
For b, I think a lot of it has to do with dyno inconsistencies. A couple of us ran a rolling dyno (used for Group N rally cars IIRC) and got 380whp for stock R38, which is in line with the loss in hp for a 4WD car. With an Amuse ECU reflash (everything else stock), it was 411whp.
All r35s prior to 2010 are 473hp (480ps). And 2010 and later is 485hp iirc.
Anyways each dyno reads differently and only two dyno types factor in real drivetrain losses for true crank hp which have confirmed those crank numbers!
Those very dynos confirm a 10% friction loss just as nissan stated due to low friction bearings and dual clutch trans which has very little power loss.
Search hyper power at GTRCenter for the articles that prove it.
:D
Trav
Well I was pretty close.................
1 - 16 of 16 Posts
