1 - 7 of 7 Posts
it to convert from push to pull on an RB25 Fatboy box ?
I have got a nissmo super coppermix clutch for my setup but once it arrived found it to be a pull setup. fcuk ..!
So, what do I need and where can I get the parts from ?
I have some experience in converting these as I played with 116 Alfa Romeos at some stage.
Any thoughts ??
If it is the same R32/R33 GT-R box, Then you will need the backing plate and the fork and pivot from a "Pull" box. You may find that you could use old GT-R parts?
Thanks bud, pretty much what I thought I`d have to do.
Just built the best RB25/Z32 combo box for her and now this. I will see if the backing plate is the same or similar.
I may have to weld a bung on the rb box for the fulcrum post.
Any idea of where I could source these parts ?? I am in South Africa..
1 - 7 of 7 Posts
