1 - 13 of 13 Posts
i already did hear about this for a long time ago.
i did use the apexi on the s13 and i have the hks on the GTR. i did not have any problem with both of them.
the only diference it that i notice,i was that the hks ones, do get holder quicker.
cheers
Barros777
Not sure if its still the case but K&N's used to have issues on cars with hotwire AFM's due to the oil attaching itself to the wire and causing problems.
TT
I think I have heard that as well. Not sure of the exacts but on the SXOC people used to moan about the oil from the filter playing havoc with the AFM - I am sure this is why I was advised to go for the Apexi.
Kp
the apexi's are by far the best for filtration and durability ..plus they look cool..:chuckle:
the hks ones are very poor in my humble opinion..just a piece of foam
I run a std airbox with Nismo filter and the bung removed from the air ram on the side of the inner wing. Works great for me and MINES and NISMO;)
Indeed Dave's correct as MINES rate the airbox with a performance filter good for up to 500BHP!
I saw the same test when I had my R33 so got rid of the HKS mushrooms for the APEXI & have to agree that they are the better ones.
HKS - good for lots of airflow if you don't require good filtering!
HKS are normally on big single turbos, stay away from them would be my view
even the Greddy Air intakes are rather pony
apexis are the better option.
Sard are also quite good.
M's Factory are K&Ns
Stock box with a mines panel filter, or nismo s tune panel is a good option, with the nismo scoop, like on kadirs car
i went the ARC box route with is a combination of both, and has one of the best filtrations available.
1 - 13 of 13 Posts
