1 - 9 of 9 Posts
I took my engine out of my R32GT-R today for a coming uppgrade.
I was happy finding a twin plate Nismo clutch (i don´t know wich model it is), but i want to messiure and perhaps service the clutch disks.
My question is then how thick the disks are when the clutch is new?
I have seen som figures that the Nismo twin plate G-max have 3.5mm new and minimum 2.6mm, is this correct? is mine a G-max?
Some pictures of the clutch:
One of the two disks:
Thanks,
Peter
hi mate, that clutch is the older g-max. the first twin they made. slightly less spring pressure thats all. but yes its a g-max. plates are 3.6mm new. and 2.6mm when knackered. just removed mine and they are 3.6 and 3.3.. if you are going to re-use the plates put the thicker of the two nearest the flywheel as this one wares first and faster intially.hope that helps bernie.
Hi Bernie,
Thanks alot for this info, i will messiure my plates this week and see if any of the two needs replacement.
Is there some cheeper exange plates avalible on the market if i have to replace or do i need to by the Nismo original ones?
How much is the nismo ones btw?
Thanks,
Peter
no probs peter. think you may have to buy from prospec in london or find a nismo dealer, last resort is search in japan for some good secondhand ones...sorry bernie.
Discussion Starter #7
Ok, thanks, do you have a link to prospec´s webpage? I tried www.prospec.co.uk and found bathroom equipment *he he*:eek:
Discussion Starter #9
Hi Bernie,
I messiured the plates and one of them were 3.6mm and the other one was 3.1mm.
Regarding your info about wich plate that wares first:
They must have switched them because the plate with 3.1mm thicknes wasen´t mounted nearest the flywheel.
I think that these disks will last atleast this summer?
Cheers,
Peter
1 - 9 of 9 Posts
