1 - 7 of 7 Posts
As per title, i should change brake fluid on my R34 GTR.
Is there a proper way to bleed the system well and also the clutch oil (i think that should be the same...)?
My clutch is an ATS carbon twin plate.
Is there a guide or someone tell me the correct procedure? :bowdown1:
Thank you mates!!!
I used a one-way valve on the calipers bleed screw and just braked and braked until I saw the new brake oil coming out without air.
I wouldn't see why not ;)
Bleeding the OEM clutchline with the damper in place is a bit more painfull if you don't use the one-way valve though...
Thanks mates, but I don't understand this one-way valve where and how do I connect? Do you have any photos to better understand?
Dot 4 oil for the clutch same as brakes.
I bled my clutch with 3 people one pumping the clutch about 5 times then holding it down, person under the car undoing the bleed nipple on the slave cylinder and let fluid came out c while someone else kept topping it up. Close nipple and repeat until clutch pedal feels right and all air is out.
1 - 7 of 7 Posts
