Could someone let me know how you engage a rolling launch with the latest EcuTek software.
Thanks I'll speak to him regarding a fixAs above really - 99 setting with suspension in R mode (Iain changed this to preserve standard cruise function in the 99 map). Target boost is pre-set by the tuner but adjustability may be the subject of later revisions I believe.
VXRCYMRU I also killed my car using rolling launch (various warnings, limp mode etc) which turned out to be a software bug in an early version, according to Iain. All sorted now.
Same was a bug, patched out and no issues since.VXRCYMRU I also killed my car using rolling launch (various warnings, limp mode etc) which turned out to be a software bug in an early version, according to Iain. All sorted now.
I got a Word document from Iain with detailed instructions for all the featuresI going to ask Ian, but I assume all the features as programmed by Litchfield are documented, as each master tuner has options they can choose to trigger features such as rolling launch.
What speed and gear did you find most enjoyable?Enjoyed this feature yesterday, with GTCs aggressive rolling launch the car is popping and banging while building boost before pinning you to the seat :chuckle:
2nd or 3rd gear are the bestWhat speed and gear did you find most enjoyable?
