21 - 26 of 26 Posts
Hammy you can share DSL with just the DSL modem if you use a software gateway...
XP has this built in - I use it to network three PC's at home - coz Im sad.
With DSL you can only network 4 PC's unlike ISDN, which can network hundreds (It becomes very, very slow! My school used to have that setup!)
I should have pointed that out ;)
Discussion Starter #23
looks like ill be getting broad band asap!
cheers for the replys
Discussion Starter #25
simon
bloddy hell, 54 posts in what 3 days
your hooked arnt you! ;)
Goto to admit it is addictve:p it does help when I work on the computer most of the day, so it can constantly been checked, while I do other things (also the advantage of broad band) however, disadvantage is like today i have been stuck in doors working, while it was gorgeous weather out side, and the Ferrari is sitting in the garage:( (note to myself prioritise better) hopefully tomorrow will be good.
Also most of the posts have been trying to answer questions for my self, when i want to know something i want to do it all there and then. (slightly obsesive) i will probably worse when I get the car:p
21 - 26 of 26 Posts
