Thanks for the reply, how do either of these stack up against the meister r?
Depending on which version of the MeisterR you are talking about.
The BC BR, HSD MonoPro, and the MeisterR Zeta-R are around the same page.
Dual perch design, adjustable mono-tube dampers.
We probably send a little more time to ensure our dampers will provide a more compliant ride quality over the UK road surfaces, as that is something we really look into during our design phase.
The HSD DualTech (DT) is a twin-tube damper so it isn't in the same performance class as the listed above.
If you are talking about the MeisterR GT1 coilovers, then it will be quite a big step up from BC and HSD.
The MeisterR GT1 are hand build in the UK and will be running along the line of the Ohlins DFV, Nitron R1, and other custom build one-way suspensions.
The GT1 are design for all around road comfort with capable track ability using advance damping technology like the Ohlins DFV, so it isn't as track focused (read uncomfortable) as the Nitron's suspensions.
If you have any other question, please feel free to let me know.
Jerrick
